VERKOCHT CPR Rottweiler intake kit & SAS plates KTM 990
ricos
Geregistreerd op: 19-2-2012
BerichtGeplaatst: Zo, 21 Sep. 2014, 10:18    Onderwerp: VERKOCHT CPR Rottweiler intake kit & SAS plates KTM 990 Reageer met quote
Te koop :
CPR Rottweiler intake voor de KTM 990 SM SMR SMT ADV SD
Het inlaatsysteem voor de LC8 990! Makes your V-Twin Bark !
Weinig gebruikt,net schoongemaakt en opnieuw ingeolied.
Er zijn veel beschikbare mappings beschikbaar op internet icm de CPR intake.
Info van Rottweiler zelf :
Benefits of the Rottweiler Intake System:
The most cost effective horsepower gains on the market. About $30 to $40 (US) per HP vs $100 to $200 for an aftermarket exhaust.
Dramatically reduces the jerky 'on-off' throttle response of the big twin. Mountain roads and tight traffic become a joy again.
Full tri layer foam element on all sides of the filter including the top, not just one side, aiding in air velocity optimization and overall filter surface area.
The outer layers of foam provide optimum filtration and load-up capacity while the inner layer is made of special self-extinguishing filter foam. Together, they five the best combination for air flow, engine protection and safety.
Specially made 'Super Tough Nylon' base plate weighs in at 1/2 that of aluminum material and significantly reduces the transfer of engine.
No tools needed to change or remove the filter. Removed in seconds.
Weight reduction of 1.6kg (3.5lbs) just by replacing the stock airbox with the Rottweiler Intake.
Removal of the stock airbox frees up an enormous amount of space in the front of the filter than can be used for accessory storage like HID ballasts, ignition controllers and such that were previously difficult to package.
Serviceability of the throttle bodies becomes drastically less difficult to get to.
High quality lifetime Buna N 'X' rings seal off the throttle bodies in 4 places.
Adds a wicked sound that while docile at cruising speeds, barks with authority when cracked open.
All necessary hardware included.
Suggestions upon installation:
It is advised but not mandatory to remove the emissions hardware when installing a Rottweiler Intake System. The part where the Secondary Air Injection (SAS or SAI) attaches to the stock air-box is removed with this installaton and if the installer wants to keep the SAS/SAI on the bike (rare), you will need to attach a small filter to the leftover hose. See our SAS Stage kits for block off kits.
CPR Rottweilerintake kit LC8 990
Rottweiler SAS block off plates
I love it when a plan comes together
Laatst aangepast door ricos op Do, 25 Sep. 2014, 19:18, in totaal 2 keer bewerkt
ricos
Nieuw berichtGeplaatst: Ma, 22 Sep. 2014, 17:40    Onderwerp: Reageer met quote
Sold ! Slotje svp thumbsup
