nieuwe garmin modellen
BerichtGeplaatst: Ma, 28 Nov. 2005, 21:41    Onderwerp: nieuwe garmin modellen Reageer met quote
ok.. effe jatten van een ander forum:
Quote:
New GPSmap 60/76 and eTrex with SiRF
Garmin GPSmap 60/76 and eTrex series are extended with new models equipped with SiRF high-sensitive GPS receiver and expandable memory. At present these models are unknown on the worldmarket, probably also in US.
Existing GPSmap og eTrex models are some of the most popular GPS receivers for outdoor use. Some users have been missing expandable memory and more sensitive GPS reception in these models. The new x-models have high-sensitive SiRFstarIII chipset receiver and expandable TransFlash? memory. Maybe we can expect that the upcoming Quest 2 Europe also has SiRF technology and expandable memory.
The preliminary information shows that GPSmap 60/76 x-models have expandable memory and SiRF chipset. It's not confirmed that the eTrex x-models have expandable memory and SiRF chipset, but most likely they have, based on the available information.
GPSmap and eTrex series have functionality for both topographic, road and sea navigation. The new x-models probably have memory capacity for all the map products and areas a user can desire.
The available information says nothing about POI, proximity alarm and avoidance functionality. It's not confirmed that the first x-models are fully compatible with european conditions, but most likely they are. Existing GPSmap and eTrex models are globally compatible.
Prices for the new models seems to be approximately 10% higher than for the predecessors. It's expected that Bass Pro Shops will receive the first units from Garmin the first week in December 2005, at present not confirmed.
This is also good news for the geocachers, as for all with need for more precise positioncalculation and enhanced satellite reception. With SiRFstarIII chipset it's possible to receive good satellite signals in f.ex. forests and areas with high buildings.
Because of the SiRF technology x-models will receive SBAS EGNOS/WAAS DGPS signals much better than the previous models. The use of EGNOS/WAAS gives position accuracy better than 3m 95% of the time in the positioncalculation.
TransFlash? memory
TransFlash? is invented by SanDisk. SanDisk has recently made a memory card with the description microSD?/TransFlash? which has become an open industry standard. It's assumed that this type of card is used in Garmin's new SiRF GPS models. A different card type might be used because this information is not confirmed yet.
MicroSD?/TransFlash? memory cards are incredibly small, only 11mm wide, 15mm long og 1mm thick. They weigh almost nothing and occupies a minimum of space. At present SanDisk produces the cards with 128mb, 256mb og 512mb memory capacity. They give 5 years warranty. For a 512mb card the price is at present USD 64,99, approximately NOK 440, included norwegian moms/vat NOK 550. It's approximately NOK 1 pr mb.
HIER staat hij al in een webshop
koos van geene
Geregistreerd op: 1-11-2005
BerichtGeplaatst: Do, 1 Dec. 2005, 23:47    Onderwerp: Reageer met quote
ik gebruik hier ook een GPS map60c ,die heb op m,n stuur gemonteerd met silenblokjes ,of hoe je dat ook schrijft,als ik met m,n franse enduro maatjes op pad ben staat ie aan,want zei gidsen altijd en doen dat al 30 jaar,na de rit als ik thuis kom laad ik alles in de pc,werkt perfect , ik heb van dit gebied topografische kaarten en kan zo alles mooi uitwerken.
